Adding or Removing a Favorite Activity
The list of your favorite activities appears when you press Start from the watch face, and it provides quick access to the activities you use most. The first time you press Start to start an activity, the device prompts you to select your favorite activities. You can add or remove favorite activities at any time.
  1. Hold MENU.
  2. Select Settings > Activities & Apps.
    Your favorite activities appear at the top of the list with a white background. Other activities appear with a black background.
  3. Select an option:
    • To add a favorite activity, select the activity, and select Set as Favorite.
    • To remove a favorite activity, select the activity, and select Remove from Favorites.
Copyright © Garmin. All rights reserved.GUID-46975363-04DD-408E-95A7-17D40075FC50 v4
