Setting Your Elevation
If you have accurate elevation data for your present location, you can manually calibrate the altimeter on your device.
  1. Select Navigation > Menu symbol > Set Elevation.
  2. Enter the elevation, and select .
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
