About the Speed and Cadence Sensors
Cadence data from the cadence sensor is always recorded. If no speed and cadence sensors are paired with the device, GPS data is used to calculate the speed and distance.
Cadence is your rate of pedaling or “spinning” measured by the number of revolutions of the crank arm per minute (rpm).
Parent Topic: Installing the Cadence Sensor
