Before you can pair, you must put on the heart rate monitor or install the sensor.
Pairing is the connecting of
ANT+® wireless sensors, for example, connecting a heart rate monitor with your
Garmin® device.
Bring the device within 3 m (10 ft.) of the sensor.
NOTE:
Stay 10 m (33 ft.) away from other riders'
ANT+ sensors while pairing.
Select
Select an option:
A list of available sensors appears.
Select one or more sensors to pair with your device.
Select
Add.
When the sensor is paired with your device, the sensor status is
Connected. You can customize a data field to display sensor data.
