Using the Backlight
You can tap the touchscreen to turn on the backlight.
NOTE:
You can adjust the backlight timeout (Display Settings).
- From the home screen or a data screen, swipe down from the top of the screen.
- Select Brightness.
Select an option:
To manually adjust the brightness, use the arrows.
To allow the device to automatically adjust the brightness based on the ambient light, select Auto Brightness.
Parent Topic: Home Screen Overview
