If your device was packaged with an
ANT+® sensor, they are already paired and can be activated during initial setup.
Hold
to turn on the device.
Go outside, and wait while the device locates satellites.
The satellite bars turn green when the device is ready.
From the home screen, select
Select
to start the timer.
NOTE:
History is recorded only while the timer is running.
Swipe left or right to view additional data screens.
You can swipe down from the top of the data screens to view the connections screen.
If necessary, tap the screen to view the timer overlay.
Select
to stop the timer.
TIP:
Before you save this ride and share it on your
Garmin Connect™ account, you can change the ride type. Accurate ride type data is important for creating bike friendly courses.
Select
Save Ride.
Select
