Updating Your Activity Profile
You can customize ten activity profiles. You can customize your settings and data fields for a particular activity or trip.
- Select .
- Select an option:
- If necessary, edit the name and color for the profile.
Select an option:
Select Data Screens to customize the data screens and data fields (Customizing the Data Screens).
Select Segments to turn on your enabled segments (Enabling Segments).
Select Alerts to customize your training alerts (Alerts).
Select to set how laps are triggered (Marking Laps by Position).
Select to change when the activity timer automatically pauses (Using Auto Pause).
Select to automatically enter sleep mode after five minutes of inactivity (Using Auto Sleep).
Select to customize the display of the training data screens when the activity timer is running (Using Auto Scroll).
Select Timer Start Mode to customize how the device detects the start of a ride and automatically starts the activity timer (Starting the Timer Automatically).
Select Navigation to customize the map settings (Map Settings) and routing settings (Route Settings).
Select GPS Mode to turn off GPS (Training Indoors) or change the satellite setting (Changing the Satellite Setting).
All changes are saved to the activity profile.
