System Settings
Select .
- Language
Sets the language displayed on the device.
- Time
Sets the time settings (Time Settings).
- Backlight Timeout
Sets the length of time before the backlight turns off.
- Tones
Turns audible tones on or off. You can set tones for keys and alert messages.
- Units
Sets the units of measure used on the device.
- GLONASS
Turns GLONASS on or off. By default, the device uses GPS to locate satellites. For increased performance in challenging environments and faster GPS position location, you can enable GPS and GLONASS. Using GPS and GLONASS reduces battery life more quickly than using only GPS.
- Software Update
Allows you to check for software updates.
- About
Displays the software version and unit ID.
Parent Topic: Customizing Your Device
