Data Fields
Some data fields require optional accessories to display data.
- Average HR
The average heart rate for the current activity.
- Avg. Cadence
Cycling. The average cadence for the current activity.
- Avg. Lap Time
The average lap time for the current activity.
- Avg. Speed
The average speed for the current activity.
- Battery
The remaining battery power.
- Battery Status
The remaining battery power of a bike light accessory.
- Beam Ang. Status
The headlight beam mode.
- Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
- Calories
The amount of total calories burned.
- Distance
The distance traveled for the current track or activity.
- Distance to Dest.
The remaining distance to the final destination. You must be navigating for this data to appear.
- Distance to Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
- Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
- Elevation
The altitude of your current location above or below sea level.
- ETA at Dest.
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
- ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
- Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
- Heading
The direction you are moving.
- Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
- HR %Max.
The percentage of maximum heart rate.
- HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
- Lap Cadence
Cycling. The average cadence for the current lap.
- Lap Distance
The distance traveled for the current lap.
- Lap HR
The average heart rate for the current lap.
- Laps
The number of laps completed for the current activity.
- Lap Speed
The average speed for the current lap.
- Lap Time
The stopwatch time for the current lap.
- Location at Dest.
The last point on the route or course.
- Location at Next
The next point on the route or course.
- Maximum Speed
The top speed for the current activity.
- Odometer
A running tally of distance traveled for all trips. This total does not clear when resetting the trip data.
- Power - 3s Avg.
The 3-second moving average of power output.
- Power - Avg.
The average power output for the current activity.
- Power - kJ
The accumulated work performed (power output) in kilojoules.
- Power - Lap
The average power output for the current lap.
- Power - Max.
The top power output for the current activity.
- Power Zone
The current range of power output (1 to 7) based on your custom settings.
- Speed
The current rate of travel.
- Sunrise
The time of sunrise based on your GPS position.
- Sunset
The time of sunset based on your GPS position.
- Time
The stopwatch time for the current activity.
- Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
- Time to Dest.
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
- Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
- Total Ascent
The total elevation distance ascended since the last reset.
- Total Descent
The total elevation distance descended since the last reset.
