Turning On Battery Save Mode
Battery save mode adjusts the settings automatically to extend the battery life for longer rides. During an activity, the screen turns off.
You can enable automatic alerts and tap the screen to wake it up. Battery save mode records GPS track points and sensor data less frequently. Speed, distance, and track data accuracy are reduced.
NOTE:
History is recorded in battery save mode when the timer is running.
- Select .
- Select the alerts that wake up the screen during an activity.
After your ride, you should charge your device and disable battery save mode to use all the device features.
Parent Topic: Maximizing Battery Life
