Adjusting an Auto Guidance Path
  1. Select Nav Info > Routes.
  2. Select a path, and select Edit > Adjust Path.
    TIP: When navigating an Auto Guidance path, select the path on the navigation chart, and select Adjust Path.
  3. Select a location on the path.
  4. Select an option:
    • On device with keys, use the arrow keys.
    • On device with touchscreens, drag the path.
  5. If necessary, select a point, and select Remove.
  6. Select Done.
Copyright © Garmin. All rights reserved.GUID-E496ED9A-F874-45F8-BB02-F69A61BFB042 v6
