Browsing for and Navigating a Recorded Track
Before you can browse a list of tracks and navigate to them, you must record and save at least one track.
  1. Select Nav Info > Tracks > Saved Tracks.
  2. Select a track.
  3. Select Follow Track.
  4. Select an option:
    • To navigate the track from the starting point used when the track was created, select Forward.
    • To navigate the track from the destination point used when the track was created, select Backward.
  5. Review the course indicated by the colored line.
  6. Follow the line along each leg in the route, steering to avoid land, shallow water, and other obstacles.
Copyright © Garmin. All rights reserved.GUID-0D15DF1D-FE0A-4101-9423-8240088D45C2 v5
