Using In-Call Options
While on a call, you can select in-call options from the map.
  • To transfer audio to your phone, select Transfer call to headset.
    TIP: You can use this feature if you want to turn off your device and remain on the call, or if you need privacy.
  • To use the dial pad, select Dial pad.
    TIP: You can use this feature to use automated systems, such as voice mail.
  • To mute the microphone, select Mute microphone.
  • To hang up, select End call.
Copyright © Garmin. All rights reserved.GUID-CBA24409-6FB7-435D-978D-ED87272C2D8A v5
