Avoiding Toll Roads
Your device can avoid routing you through areas that require tolls, such as toll roads, toll bridges, or congestion areas. The device may still include a toll area in your route if no other reasonable routes are available.
  1. Select Settings > Navigation.
  2. Select an option:
    NOTE: The menu changes based on your area and the map data on your device.
    • Select Toll Roads.
    • Select Tolls and Fees > Toll Roads.
  3. Select an option:
    • To be asked each time before routing through a toll area, select Always Ask.
    • To always avoid tolls, select Avoid.
    • To always allow tolls, select Allow.
  4. Select Save.
Copyright © Garmin. All rights reserved.GUID-CBA24409-6FB7-435D-978D-ED87272C2D8A v5
