Starting LiveTrack Sharing
Use caution when sharing your location information with others.
Before you can start sharing, you must set up the LiveTrack feature (Setting Up LiveTrack Sharing and Inviting Viewers).
You can start sharing your LiveTrack data using your Garmin DriveSmart™ device or the Smartphone Link app.
- On your Garmin DriveSmart device, select .
- On your smartphone, open the Smartphone Link app, and select .
A link to view your LiveTrack data is posted to your enabled social network accounts, and an email with the link is sent to your invited contacts. While you are sharing, viewers can click the link to track your current location, recently visited locations, and the path of your recent travels in real time.
appears in the
Garmin DriveSmart status bar while
LiveTrack sharing is active. The number of invited viewers also appears.
