Receiving notifications
WARNING
Do not read or reply to notifications while driving.
Before your Garmin DriveSmart™ device can receive notifications, you must connect it to your smartphone and to the Smartphone Link app.
From most pages, a pop-up appears when the device receives a notification from your smartphone. If the device is moving, you must verify you are a passenger and not the driver before you can view notifications.
NOTE: If you are viewing the map, notifications appear in a map tool.
  • To ignore a notification, select OK.
    The pop-up closes, but the notification remains active on your phone.
  • To view a notification, select View.
  • To listen to the notification, select View > Play.
    The device reads the notification using text-to-speech technology. This feature is not available for all languages.
  • To perform additional actions, such as dismissing the notification from your phone, select View, and select an option.
    NOTE: Additional actions are available for only some notification types and must be supported by the app generating the notification.
Copyright © Garmin. All rights reserved.GUID-CBA24409-6FB7-435D-978D-ED87272C2D8A v5
