Adding a location to your route
Before you can add a location to your route, you must be navigating a route (Starting a route).
You can add locations to the middle or end of your route. For example, you can add a petrol station as the next destination in your route.
TIP: To create complex routes with multiple destinations or scheduled stops, you can use the trip planner to plan, schedule, and save a trip (Planning a trip).
  1. From the map, select Back to previous page > Where To?.
  2. Search for a location (Finding and saving locations).
  3. Select a location.
  4. Select Go!.
  5. Select an option:
    • To add the location as the next destination in your route, select Add As Next Stop.
    • To add the location to the end of your route, select Add As Last Stop.
    • To add the location and edit the order of destinations in your route, select Add to Active Route.
The device re-calculates the route to include the added location and guides you to the destinations in order.
Copyright © Garmin. All rights reserved.GUID-CBA24409-6FB7-435D-978D-ED87272C2D8A v5
