Using in-call options While on a call, you can select in-call options from the map. To transfer audio to your phone, select . TIP: You can use this feature if you want to turn off your device and remain on the call or if you need privacy. To use the dial pad, select . TIP: You can use this feature to use automated systems, such as voice mail. To mute the microphone, select . To hang up, select . Parent Topic: Hands-free callingHomeLive services, traffic and smartphone featuresHands-free callingUsing in-call options
