Location Search Results on the Map
You can view the results of a location search on the map instead of in a list.
From the location search results, select Search results map. The nearest location appears at the center of the map, and basic information about the selected location appears at the bottom of the map.
Location search results on a map with callouts
Callout number one
Drag the map to view additional search results.
Callout number two
Additional search results. Select to view another location.
Callout number three
Selected location summary. Select to view detailed information about the selected location.
Callout number four Go!
Select to start navigating to the location using the recommended route.
Callout number five Search results list
Select to view the search results in a list.
Copyright © Garmin. All rights reserved.GUID-67DA720E-963D-48A3-B7FA-DFEC1248BF79 v3
