Tips After Pairing the Devices
  • After the initial pairing, the two devices can connect automatically each time you turn them on.
  • When your phone is connected to your device, you are ready to receive voice calls.
  • When you turn on the device, it tries to connect to the last phone to which it was connected.
  • You might need to set your phone to connect to the device automatically when the device is turned on.
  • To place phone calls, the contact sharing permission must be enabled for the navigation device in the Bluetooth® settings on your phone.
  • You should verify the Bluetooth features you want to use are enabled (Enabling or Disabling Bluetooth Features).
Copyright © Garmin. All rights reserved.GUID-75C81B9F-EB18-493C-AAAB-D196FE181AC3 v2
