Setting an Alarm
You can set up to ten separate alarms. You can set each alarm to sound once or to repeat regularly.
  1. From the watch face, hold MENU.
  2. Select Clock > Alarm Clock > Add Alarm.
  3. Select Time, and enter the alarm time.
  4. Select Repeat, and select when the alarm should repeat (optional).
  5. Select Sounds, and select a type of notification (optional).
  6. Select Backlight > On to turn on the backlight with the alarm.
  7. Select Label, and select a description for the alarm (optional).
Copyright © Garmin. All rights reserved.GUID-EF62730A-5896-4ECB-9BD8-3CFCE26AA485 v4
