Setting Navigation Alerts
You can set alerts to help you navigate to your destination.
  1. Hold MENU.
  2. Select Settings > Navigation > Alerts.
  3. Select an option:
    • To set an alert for a specified distance from your final destination, select Final Distance.
    • To set an alert for the estimated time remaining until you reach your final destination, select Final ETE.
    • To set an alert when you stray from the course, select Off Course.
    • To enable turn-by-turn navigation prompts, select Turn Prompts.
  4. If necessary, select Status to turn on the alert.
  5. If necessary, enter a distance or time value, and select Checkmark.
Copyright © Garmin. All rights reserved.GUID-EF62730A-5896-4ECB-9BD8-3CFCE26AA485 v4
