My music cuts out or my headphones do not stay connected
When using a D2™ device connected to headphones using Bluetooth® technology, the signal is strongest when there is a direct line of sight between the device and the antenna on the headphones.
If the signal passes through your body, you may experience signal loss or your headphones may become disconnected.
It is recommended to wear your headphones with the antenna on the same side of your body as your D2 device.
Parent Topic: Troubleshooting
