Creating a Route on the Map You can create a route by selecting points on the map or by drawing the route on the map. If necessary, select a map product. If necessary, change the activity. Select a location for the saved route (Selecting a Location for Saved Data Files). Select Tools > Route. If necessary, close the new route window. Select a starting point for your route. Select points to add to the route. Right-click to save the route. TIP: You can also press esc on the keyboard to save the route. The route appears as a colored line on the map. Parent Topic: Route Creation
Creating a Route on the Map You can create a route by selecting points on the map or by drawing the route on the map. If necessary, select a map product. If necessary, change the activity. Select a location for the saved route (Selecting a Location for Saved Data Files). Select Tools > Route. If necessary, close the new route window. Select a starting point for your route. Select points to add to the route. Right-click to save the route. TIP: You can also press esc on the keyboard to save the route. The route appears as a colored line on the map. Parent Topic: Route CreationHomeRoutesRoute CreationCreating a Route on the Map
