Connecting the Collar to a Computer
NOTICE
To prevent corrosion, you should dry the contacts on the collar and the surrounding area before connecting the charging clip.
You can connect the collar to your computer to use with programs like BaseCamp™. The collar is not a mass storage device.
  1. Snap the charging clip onto the collar.
  2. Plug the small end of the USB cable into the mini-USB port on the charging clip cable.
  3. Plug the other end of the USB cable into a USB port on the computer.
Copyright © Garmin. All rights reserved.GUID-B5034C68-A161-482B-AA7E-1971E02FACAA v4
