Setting an Alert
- From the watch face, select .
- Select an activity.
- Select the activity settings.
- Select Alerts.
Select an option:
Select Add New to add a new alert for the activity.
Select the alert name to edit an existing alert.
- If necessary, select the type of alert.
- Select a zone, enter the minimum and maximum values, or enter a custom value for the alert.
- If necessary, turn on the alert.
For event and recurring alerts, a message appears each time you reach the alert value. For range alerts, a message appears each time you exceed or drop below the specified range (minimum and maximum values).
Parent Topic: Alerts
