Data Fields
Accuracy of GPS
The margin of error for your exact location. For example, your GPS location is accurate to within +/- 12 ft. (3.65 m).
Ambient Pressure
The uncalibrated environmental pressure.
Ascent - Average
The average vertical distance of ascent since the last reset.
Ascent - Maximum
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
Ascent - Total
The total elevation distance ascended since the last reset.
Barometer
The calibrated current pressure.
Battery Level
The remaining battery power.
Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
Cadence
The number of revolutions of the crank arm or number of strides per minute. Your device must be connected to a cadence accessory for this data to appear.
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Descent - Average
The average vertical distance of descent since the last reset.
Descent - Maximum
The maximum rate of descent in feet per minute or meters per minute since the last reset.
Descent - Total
The total elevation distance descended since the last reset.
Distance to Dest.
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance to Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Elevation
The altitude of your current location above or below sea level.
Elevation - Maximum
The highest elevation reached since the last reset.
Elevation - Minimum
The lowest elevation reached since the last reset.
ETA at Destination
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
Glide Ratio to Dest
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
GPS Signal Strength
The strength of the GPS satellite signal.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
Location (lat/lon)
The current position in latitude and longitude regardless of the selected position format setting.
Location (selected)
The current position using the selected position format setting.
Odometer
A running tally of distance traveled for all trips. This total does not clear when resetting the trip data.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Pointer
An arrow points in the direction of the next waypoint or turn. You must be navigating for this data to appear.
Speed
The current rate of travel.
Speed - Maximum
The highest speed reached since the last reset.
Speed - Moving Avg.
The average speed while moving since the last reset.
Speed - Overall Avg.
The average speed while moving and stopped since the last reset.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Time of Day
The current time of day based on your current location and time settings (format, time zone, daylight saving time).
Time to Destination
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
To Course
The direction in which you must move to get back on the route. You must be navigating for this data to appear.
Trip Odometer
A running tally of the distance traveled since the last reset.
Trip Time - Moving
A running tally of the time spent moving since the last reset.
Trip Time - Stopped
A running tally of the time spent not moving since the last reset.
Trip Time - Total
A running tally of the total time spent moving and not moving since the last reset.
Turn
The angle of difference (in degrees) between the bearing to your destination and your current course. L means turn left. R means turn right. You must be navigating for this data to appear.
Update Rate
The frequency at which the collar sends data to the handheld device.
Velocity Made Good
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Vertical Speed
The rate of ascent or descent over time.
Vertical Speed to Dest
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
Waypoint at Dest
The last point on the route to the destination. You must be navigating for this data to appear.
Waypoint at Next
The next point on the route. You must be navigating for this data to appear.
Copyright © Garmin. All rights reserved.GUID-24A16A13-43AC-48C0-9C57-69DFA7CAE923 v2
