Routing Settings
The device calculates routes optimized for the type of activity you are doing. The routing settings available vary based on the activity selected.
Select Setup > Routing.
Guidance Method
Sets the preference for optimizing route calculation based on distance, time, on-road, or off-road routing.
Calculate Routes for
Sets the mode of transportation for which to calculate routes.
Lock On Road
Locks the position icon, which represents your position on the map, onto the nearest road.
Off Road Transitions
Sets how the device routes from one point on the route to the next. This setting is available only for some activities. Distance routes you to the next point on the route when you are within a specified distance of your current point.
Avoidance Setup
Sets the road types to avoid while navigating. This setting is available only for some activities.
Copyright © Garmin. All rights reserved.GUID-24A16A13-43AC-48C0-9C57-69DFA7CAE923 v2
