Long-Term Storage
NOTICE
The normal long-term decrease in the charging capacity of lithium-ion batteries can be accelerated by exposure to elevated temperatures. Storing a fully charged device in a location with a temperature outside the long-term storage temperature range can significantly reduce its recharging capacity.
When you do not plan to use the handheld device for several months, the battery should be removed. Stored data is not lost when the battery is removed.
When you do not plan to use the collar for several months, the battery should be charged to about 50%. The device should be stored in a cool, dry place with temperatures around the typical household level. After storage, the collar should be fully recharged before use.
Copyright © Garmin. All rights reserved.GUID-24A16A13-43AC-48C0-9C57-69DFA7CAE923 v2
