Editing a Route
  1. Select Menu > Route Planner.
  2. Select a route.
  3. Select Edit Route.
  4. Select a point.
  5. Select an option:
    • To view the point on the map, select Review.
    • To change the order of the points on the route, select Move Up or Move Down.
    • To insert an additional point on the route, select Insert.
      The additional point is inserted before the point you are editing.
    • To remove the point from the route, select Remove.
Copyright © Garmin. All rights reserved.GUID-07D423F1-E5A9-4C41-98E5-11BE34A89E84 v4
