Customizing the Data Fields
Before you can customize the data fields on the map, you must enable the data fields (Enabling the Map Data Fields).
You can customize the data fields and dashboards of the map, compass, elevation plot, and trip computer.
  1. Open the page for which you will change the data fields.
  2. Select a data field to customize.
  3. Select the new data field.
    For data field descriptions, see Data Field Options.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
