Adding a Dog Using the Track and Train Codes
NOTE: This feature varies based on dog collar device type and feature availability in your area.
Before you can add a dog using the track and train codes, the dog owner must find the track and train codes (Finding the Dog ID and Track and Train Codes) and tell them to you.
If you are not near the dog you want to add or you cannot put the collar into pairing mode, you can add the dog using the track and train codes.
  1. Select Add Dog.
  2. When asked if you are near the collar, select No.
  3. When asked if you know the track and train codes, select Yes.
  4. Enter the track or train code for the collar, and select Checkmark.
    The dog’s track code allows you to track the dog. The dog’s train code allows you to both track and train the dog.
  5. Enter the name of the dog, and select Checkmark > OK.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
