Turning Off the Transmitter
You can disable transmitting to conserve battery power on the handheld device when you are not communicating with contacts.
NOTE: At cold temperatures, if you transmit when the battery is low, the device may shutdown.
Select Setup > Contacts > Pairing Setup > Transmitting > Off.
When the transmitter is off, you cannot send your location or messages to contacts.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
