Customizing the Main Menu
You can move, add, and delete items in the main menu.
  1. From the main menu, select Setup > Main Menu.
  2. Select a menu item.
  3. Select an option:
    • Select Move Up or Move Down to change the location of the item in the list.
    • Select Remove to delete an item from the list.
    • Select Add Page to place an item on the list after you have removed it.
    • Select Menu > Restore Defaults to reset the order of all items in the menu.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
