Recording Track Logs
  1. Select Menu > Setup > Tracks > Track Log.
  2. Select Record, Do Not Show or Record, Show On Map.
    If you select Record, Show On Map, a line on the map indicates your track.
  3. Select Record Method.
  4. Select an option:
    • To record tracks at a variable rate that create an optimum representation of your tracks, select Auto.
    • To record tracks at a specified distance, select Distance.
    • To record tracks at a specified time, select Time.
  5. Select Interval.
  6. Complete an action:
    • If you selected Auto for the Record Method, select an option to record tracks more or less often.
    NOTE: Using the Most Often interval provides the most track detail, but fills up the device memory quicker.
    • If you selected Distance or Time for the Record Method, enter a value, and select Checkmark.
As you move with the device turned on, a track log is created.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
