Altimeter Settings
Select Setup > Altimeter.
Auto Calibration
Automatically calibrates the altimeter each time the device is turned on.
Barometer Mode
Sets how the device measures barometric information. Variable Elevation allows the barometer to measure changes in elevation while you are moving. Fixed Elevation assumes the device is stationary at a fixed elevation, so the barometric pressure should change only due to weather.
Pressure Trending
Sets how the device records pressure data. Save Always records all pressure data, which can be helpful when you are watching for pressure fronts.
Plot Type
Sets the type of data recorded and displayed in the plot. Records elevation changes over a period of time or distance, records barometric pressure over a period of time, or records ambient pressure changes over a period of time.
Calibrate Altimeter
Calibrates the altimeter.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
