Adding a Contact Using a Contact ID
Before you can add a hunter using a contact ID, the hunter must find the contact ID (Finding Your Contact ID) and send it to you.
If you are not near the hunter you want to add, you can add the hunter using a contact ID.
  1. On your handheld device, select Menu > Contacts > Add.
  2. When asked if you are near the other handheld device, select No.
  3. When asked if you know the contact ID, select Yes.
  4. Select the contact ID for the contact you are adding.
  5. Enter the name of the contact, and select Checkmark > OK.
The contact is added to your handheld device.
You can repeat this procedure using another hunter's handheld device to add your contact ID to that device.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
