Tips for Pairing ANT‍+ Accessories with Your Garmin Device
  • Verify that the ANT‍+® accessory is compatible with your Garmin® device.
  • Before you pair the ANT‍+ accessory with your Garmin device, move 10 m (32.9 ft.) away from other ANT‍+ accessories.
  • Bring the Garmin device within range 3 m (10 ft.) of the ANT‍+ accessory.
  • After you pair the first time, your Garmin device automatically recognizes the ANT‍+ accessory each time it is activated. This process occurs automatically when you turn on the Garmin device and only takes a few seconds when the accessories are activated and functioning correctly.
  • When paired, your Garmin device receives data from only your accessory, and you can go near other accessories.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
