Changing Your Contact ID
If you are experiencing interference from other collars or handheld devices in the area, you might need to change the contact ID for your handheld device.
  1. Select Setup > Contacts > Pairing Setup > ID.
  2. Select a contact ID that is not yet assigned to another device in the area.
    If you select a contact ID that interferes with devices in the area, you should select a new contact ID.
Each time a contact changes their contact ID, you must update the contact ID in your handheld device(Updating a Contact ID).
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
