Initiating an Emergency Alert
Before you can initiate an emergency alert, you must turn on the transmitter (Turning On the Transmitter).
Before someone can receive your emergency alert, someone must add you as a contact (Adding a Contact Using MURS/VHF).
You can use an emergency alert when you need immediate assistance and you are away from your group.
Select Menu > Contacts > Emergency alert > Yes.
When your contact accepts your emergency alert request, the device displays a message indicating that your contact has started navigating to your location.
After receiving the alert, your contacts can navigate to your location.
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
