Adding Alternate Time Zones
You can display the current time of day in additional time zones on the alternate time zones widget. You can add up to four alternate time zones.
NOTE: You may need to add the alternate time zones widget to the widget loop (Customizing the Widget Loop).
  1. From the watch face, hold MENU.
  2. Select Clocks > ALT. TIME ZONES > Add Alt. Time Zone.
  3. Select a time zone.
  4. If necessary, rename the zone.
Copyright © Garmin. All rights reserved.GUID-FFD1507E-4334-4F3A-A927-C80BA10A9918 v5
