Pairing the Varia RCT715 with a Compatible Edge Bike Computer
You can pair your Varia™ device with a compatible Edge® bike computer through an open connection using ANT+® technology. After the initial pairing, the Edge bike computer automatically connects to the Varia device when you start your activity and the device is active and within range. When paired, the device controls appear on the compatible bike computer. You can also control the camera on the compatible bike computer. For more information about connection types, go to garmin.com/connectiontypes.
TIP:
To check if your bike
computer is compatible, go to garmin.com/cycling, select Radars & Lights, select your
Varia device, and select the Compatible Devices tab.
When the radar device is paired with your
Edge bike computer, the sensor status is
Connected. The
(radar) and
(bike light) status icons appear solid on the top banner of the home screen.
Parent Topic: Edge Bike Computer Settings
