Customizing Device Settings with Your Edge Bike Computer
WARNING
The tail light can be programmed to emit light at varying degrees of brightness and flash at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
Before you can customize Varia™ RCT715 settings with your Edge® bike computer, you must pair the devices (Pairing the Varia RCT715 with a Compatible Edge Bike Computer).
  1. Select Menu symbol > Sensors > Lights.
  2. Select an option:
    • Select Enable to enable the light network.
    • Select Network Options > Test Lights to verify that each light in your network is set up correctly (Testing the Light Network).
    • Select a light to view device information and customize each light in your network (Light Network Settings).
GUID-FF49DAFA-3213-4C92-924F-2532424071B1 v4
September 2025
