Specifications
General
Weight |
340 g (12.0 oz.) |
Water resistance |
IEC 60529 IPX7 (front of stereo only, when properly installed) |
Operating temperature range |
From 0 to 50°C (from 32 to 122°F) |
Storage temperature range |
From -20 to 70°C (from -4 to 158°F) |
Input voltage |
From 10.8 to 16 Vdc |
Current (max.) |
8 A |
Current (muted) |
Less than 400 mA |
Current (off) |
Less than 200 mA |
Fuse |
15 A blade type |
Wi‑Fi® wireless range |
Up to 32 m (105 ft.) |
Bluetooth® wireless range |
Up to 10 m (30 ft.) |
Wireless frequencies/protocols |
Wi‑Fi 2.4 GHz @ 15 dBm nominal Bluetooth 2.4 GHz @ 10 dBm nominal |
Compass-safe distance |
10 cm (3.9 in.) |
On-board, Class D Amplifier
Output music power per channel |
70 W max. x 2 at 2 ohm per channel |
Total output peak power |
140 W max. |
Output power per channel1 |
2 x 43 W RMS at 14.4 Vdc input, 2 ohm, 10% THD 2 x 26 W RMS at 14.4 Vdc input, 4 ohm, 10% THD |
Tuner frequencies
Tuner |
Europe and Australasia |
USA |
Japan |
FM radio frequency range |
87.5 to 108 MHz |
87.5 to 107.9 MHz |
76 to 95 MHz |
FM frequency step |
50 kHz |
200 kHz |
50 kHz |
AM radio frequency range |
522 to 1620 kHz |
530 to 1710 kHz |
522 to 1620 kHz |
AM frequency step |
9 kHz |
10 kHz |
9 kHz |
