Tools Needed
  • M10 (3/8 in.) bolts, washers, and nuts to secure the actuator to the mounting surface
    • You must use marine-grade hardware, such as 316 stainless steel, to secure the mounting base
    • You should use hex bolts, flange bolts, or other suitable fastener with a pan head to avoid damaging the mounting base
  • Tiller arm (if needed)
  • Safety glasses
  • Drill and drill bits
  • Wrenches
  • Hex bits or wrenches (to secure the actuator to the mounting base)
  • LOCTITE® 638™ retaining compound or equivalent (recommended)
  • For annual maintenance:
    • High-quality marine-grade grease compatible with nitrile seals for lubricating pivot points
    • AeroShell® 64 grease for lubricating the leadscrew inside the actuator tube
GUID-F8A3AF4C-44EB-477D-BF2E-2FE74EFB7B13 v2
October 2026
