Mounting Location Considerations
Failure to follow these considerations when selecting a mounting location for the actuator may result in damage to the actuator, damage to the vessel, or poor product performance.
This device should be mounted in a location that is not exposed to extreme temperatures or conditions. The temperature range for this device is listed in the product specifications (Specifications). Extended exposure to temperatures exceeding the specified temperature range, in storage or operating conditions, may cause device failure. Extreme-temperature-induced damage and related consequences are not covered by the warranty.
The SmartDrive™ actuator must be installed within specific extension and angle limitations, as mentioned below and defined in the specifications at the end of these instructions. Exceeding the extension or angle limitations will damage the actuator. Installation-related damage is not covered by the warranty.
When selecting a mounting location, observe these considerations.
The actuator should not be installed closer than 50 cm (20 in.) to a compass.
The actuator must be installed under deck, in a location not subject to flooding or washdown.
The base of the actuator must be mounted securely on a surface that is able to withstand the high thrusts generated by the rudder.
The actuator movement must be limited by physical stops, and not by the length of the actuator rod, or damage to the actuator will occur.
No part of the actuator or rod should contact the vessel, quadrant, or tiller arm throughout the full range of movement.
You must not exceed the 5 degree tilt at the extremes of the stroke, because it will damage the actuator.
