Drive Unit Dimensions
Drive unit dimensions with callouts
Item
Description
Measurement
1
Length from the base attachment to the tiller pin at midstroke
700 mm (27.5 in.)
2
Height from the mounting surface to the top of the actuator housing.
197 mm (7.8 in.)
3
Maximum tilt angle of the actuator when it is at the extremes of the stroke.
NOTICE
Exceeding this angle will damage the drive unit.
5 degrees above or below center
GUID-F8A3AF4C-44EB-477D-BF2E-2FE74EFB7B13 v2
October 2026
