Connecting the Actuator to Power
When connecting the power cable, you must connect it to either the appropriate breaker or you must install the included fuse. Connecting the power cable without the appropriate fuse or breaker in place may result in personal injury or product damage caused by fire or overheating, and it voids the product warranty.
You should connect the actuator power cable directly to the boat battery using the included 30 A fuse, if possible. Although it is not recommended, if you connect the power cable to a terminal block or other source, you must connect it through a 30 A breaker.
Power Cable Extensions
If necessary, you can extend the power cable using the appropriate wire gauge for the length of the extension.
Item |
Description |
Splice |
Wire gauge needed based on the length of the extension |
Fuse |
8 in. (20.3 cm) |
Battery |
8 in. (20.3 cm) |
Length of the extension needed |
| Length of Extension | Wire Gauge Needed |
Up to 15 ft. (4.6 m) |
10 AWG (5.26 mm²) extension wire |
Up to 23 ft. (7 m) |
8 AWG (8.36 mm²) extension wire |
Up to 36 ft. (11 m) |
6 AWG (13.29 mm²) extension wire |
