Recording an Indoor Climbing Activity
You can record routes during an indoor climbing activity. A route is a climbing path along an indoor rock wall.
- Press START.
Select
Climb Indoor.
The first time you start an activity, you can enable route statistics.
Select a grading system.
NOTE: The next time you start an indoor climbing activity, the watch uses these activity settings.
- Select the difficulty level for the route.
- Press START.
- Start your first route.
When you finish the route, descend to the ground.
The rest timer starts automatically when you are on the ground.
NOTE: If necessary, you can press BACK to finish the route. -
Select an option:
To save a successful route, select Completed.
To save an unsuccessful route, select Attempted.
To delete the route, select Discard.
- Enter the number of falls for the route.
- When you are done resting, press BACK, and begin your next route.
- Repeat this process for each route until your activity is complete.
- After you complete your activity, press STOP, and select Save.
Parent Topic: Indoor Activities
