Navigation Settings
You can customize the map features and appearance when navigating to a destination.
Customizing Navigation Data Screens
- Hold UP.
- Select .
Select an option:
Select to turn on or off the map.
Select to turn on or off a data field that shows routing information on the map.
Select Up Ahead to turn on or off information about upcoming course points.
Select Compass to turn on or off the guide screen that displays the compass bearing or course to follow while navigating.
Select Elevation Plot to turn on or off the elevation plot.
Select a screen to add, remove, or customize.
Setting Up a Heading Bug
You can set up a heading indicator to display on your data pages while navigating. The indicator points to your target heading.
- Hold UP.
- Select .
Setting Navigation Alerts
You can set alerts to help you navigate to your destination.
- Hold UP.
- Select .
Select an option:
To set an alert for a specified distance from your final destination, select Final Distance.
To set an alert for the estimated time remaining until you reach your final destination, select Final ETE.
To set an alert when you stray from the course, select Off Course.
To enable turn-by-turn navigation prompts, select Turn Prompts.
- If necessary, select Status to turn on the alert.
If necessary, enter a distance or time value, and select
